piston sleeve
markr1001
piston sleeve
Post by markr1001 »
Ok i just got my rebuld kit this morning. So now where am i suposed to measure the .002-.004 above the block? Is it from the inner ring which is already raised or the outer ring? Guess i need to order shims....
https://drive.google.com/file/d/1J6jLtF ... p=drivesdk
Re: piston sleeve
Mark,
I'm sure there is one or more topics about this subject. Try to use the search option.
markr1001
Re: piston sleeve
Post by markr1001 »
Ive looked and i cant find a definative answer on which surface. Reason o ask it the inner ring that it the tallest part is alot more then .004 more like.015 so i want to k ow if there is something wrong or not
Re: piston sleeve
I can't help you with that Mark. Maybe somebody else.
blackbob
Re: piston sleeve
Post by blackbob »
Mark it's the outer edge of the sleeve, that should be 2 to 4 thou above the block.
Ref I & T 'shop' manual FO21, page 24. From your side of the Pond :D
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
markr1001
Re: piston sleeve
Post by markr1001 »
Thankyou so much! I really need to buy a shop manual. Do you have a picture of the one your referancing?
blackbob
Re: piston sleeve
Post by blackbob »
Look what I found - and the right side of the Atlantic too!
They want $19.73 to post it across here :shock:
https://www.ebay.co.uk/itm/1967-I-T-FOR ... Swh0Za2p5L
It is paperback, same as the one I have, very concise and informative. Although they won't give any info on fuel injection pumps, telling you to take them to a specialist :)
