crank rod bearing clearance
markr1001
Post by markr1001 »
I am about to be reinstalling my pistons and my father in law sujests i check the rod bearing clearances first. So im going to get some plasti guage. But i cant seem to find the spec on what its supposed to be? Does anyone know? I havent received my manual in the mail yet so i cant check there and i cant seem to find it in the manual sections i have down loaded
Its a 1957 major with the 1.375 pins and 1 oring sleeve design if that matter?
blackbob
Re: crank rod bearing clearance
Post by blackbob »
From the I & T manual:
Con-rod bearings: desired clearance 0.002-0.0035; max allowable clearance 0.005. Crank should be reground if taper exceeds 0.001 or out-of-round 0.0015.
Main bearings: desired clearance 0.0025-0.004.
It doesn't say, but it's an American-published book so I guess the units are inches :D
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
markr1001
Post by markr1001 »
Awesome! I will pick up the appropriate plasti guage in the morning!
markr1001
Post by markr1001 »
