62 super major lift top gasket
Livewire84
Post by Livewire84 »
I have been searching and cannot find the gasket that is between the hydraulic lift top and rear end. Is it ok to permatex or do I need to order some gasket material and make a gasket ?
Mine has a 62 engine but has the cream colored hood and fenders and blue frame and engine, and says Ford 5000 on the hood.
peter2
Re: 62 super major lift top gasket
Post by peter2 »
I used Dirko HT http://www.elring.com/fileadmin/Dateiab ... 2-2017.pdf to seal the hydraulic top and even the the small block on top of the cover.
Peter
1963 Super Major
Livewire84
I would think that would be much easier and maybe cheaper than trying to find gasket material big enough to cut, if there isn't one available for a reasonable price.
Plus if I screw up, I have to scrap it !
Daves rusty bits
Post by Daves rusty bits »
I bought a roll of thick lining paper from a DIY shop, cut out the gasket shape and smeared both sides with grease and it worked so well I havn`t bought a gasket since - and I`ve still got 24 mtrs left! Dave
Livewire84
Forgive my ignorance but I don't understand what lining paper is. Can you explain more, so I might be able to find some ?
Daves rusty bits
Lining paper is a plain type of wallpaper used to paste to walls or ceilings to hide cracks and imperfections before final decoration. It comes in different grades of thickness, I bought a roll of thicker stuff for about £6. Being a metre wide it can make big gaskets, I did the sump with it, and it makes dirt cheap drawing paper for the granddaughters as well. Never tried sticking it to a wall though. :oops: Dave
blackbob
Post by blackbob »
Dad (a time-served mechanic) used to make gaskets from cornflakes packets :D
Although, I reckon you would need an extra-large packet to make the gasket you need :shock:
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
Livewire84
Thank you for the explanation daves rusty bits.
I found some online.
Blackbob, I don't thing I would have ever thought of cornflakes ! That seems like a art in itself !
blackbob
Post by blackbob »
I didn't mean from the cornflakes themselves - we ate those - he used to go off with the boxes :lol:
Daves rusty bits
If you go with lining paper smear the two metal sufaces with grease, it makes a good seal and sticks the gasket in place while you fit the lid on. Four dowels dropped into the top corners of the transmission make it easier to drop the lid square on first time, its a bit heavy to faf around with.
