wiring harness
Posted: Mon May 13, 2019 6:38 pm
by hazzard
Can anyone advise me where to obtain a full wiring harness for a Super Major (with alternator) that includes conduit to wire the rear end please? There are harnesses on ebay but don't seem to have the conduit. TIA.
Re: wiring harness
Posted: Mon May 13, 2019 11:22 pm
by JC
I would check Agriline. You probably won’t find one for a Super Major with an alternator, because they came with generators.
Re: wiring harness
Posted: Tue May 14, 2019 12:47 am
by oehrick
Good point JC, should be able to use the dynamo field wire in the loom as the alternator field wire - as long as the regulator is no longer in circuit which may mean a short wire extension if the one in the new loom doesn't reach the ignition switch.
Dave and I have 'spoken' on PM particularly about the protective conduit / sleeving to the back lights - is it still available anywhere chaps? or included with any of the looms ??
Re: wiring harness
Posted: Tue May 14, 2019 2:15 pm
by JC
Is this the conduit that you need? Maybe an antique auto restoration place would have it.
Re: wiring harness
Posted: Tue May 14, 2019 7:21 pm
by oehrick
Mine has a break in exactly the same place JC, must be vulnerable, a bit of black self amalgamating heat shrink sleeve is a reliable cure.
Re: wiring harness
Posted: Tue May 14, 2019 7:42 pm
by hazzard
oehrick wrote:Good point JC, should be able to use the dynamo field wire in the loom as the alternator field wire - as long as the regulator is no longer in circuit which may mean a short wire extension if the one in the new loom doesn't reach the ignition switch.
Thanks for all replies everyone, I shall search further to find some conduit.
Re: wiring harness
Posted: Wed May 15, 2019 5:46 am
by JC
oehrick wrote:Mine has a break in exactly the same place JC, must be vulnerable, a bit of black self amalgamating heat shrink sleeve is a reliable cure.
That is just a parts tractor, Rick, so I don't really need to repair the wire loom. Its good advice for the guys that need to fix theirs. None of my other Majors have rear lights.
Re: wiring harness
Posted: Wed May 15, 2019 6:32 pm
by mathias1
hazzard wrote:oehrick wrote:Good point JC, should be able to use the dynamo field wire in the loom as the alternator field wire - as long as the regulator is no longer in circuit which may mean a short wire extension if the one in the new loom doesn't reach the ignition switch.
I got mine here:
https://www.autoelectricsupplies.co.uk/ ... ategory/66
Re: wiring harness
Posted: Wed May 15, 2019 8:02 pm
by hazzard
mathias1 wrote:hazzard wrote:oehrick wrote:Good point JC, should be able to use the dynamo field wire in the loom as the alternator field wire - as long as the regulator is no longer in circuit which may mean a short wire extension if the one in the new loom doesn't reach the ignition switch.
I got mine here:
Thanks mathias1, will use them.
