62 super major starter and injector rebuild
Posted: Tue Jan 28, 2020 5:58 am
I have a 1962 super major. I am looking for a injector rebuild kit, and found a injector tip replacement online. The replacement tip advertisement, says it is suitable for a Fordson super major as well as a older Ford thousand series, like a Ford 4000. Does this sound correct ?
They both use the same tip, and same size sealing rings at the top, and copper washer at the bottom of the injector ?
I am also looking at having to get a new starter possibly.
My starter now is the original handle activated starter type of Lucas starter. It is a m45g, I believe.
I was going to have it rebuilt, if possible but found one online that says it a direct replacement for a Fordson Super Major, for a pretty fair price.
My question is all the original Fordson ads say the starter has a 11 tooth pinion. The older Ford 4000 series series starter, that supposedly will fit a Fordson and a Ford has a 10 tooth starter pinion . Does anyone have experience will converting to this style starter, as it is alot easier for me to acquire than trying to find a shop to rebuild the original Fordson starter.
Will the 10 tooth starter work in place of a 11 tooth starter ?
My original thoughts are no, but was hoping someone had tried it before, with possible success.
Thanks ahead of time !
