Raised pto
Posted: Sun Mar 29, 2020 7:31 pm
by mathias1
A while ago I bought a raised pto which I want to fit on the super 4. I tought it might be a good idea to check the seals and bearings before installing it. I did make some pictures while taking it apart
The bearings all seam fine. I cleaned out most of the muck in the box and removed the old seal. The size of the seal is the same as a the one for the standard pto.
If someone needs more info or pictures, just let me know. I haven't put it back together yet.
Didn't find a wide seal, but I guess this will do.
Re: Raised pto
Posted: Sun Apr 12, 2020 7:46 am
by Emiel
Interesting. Do you have one with gear reduction or with 1:1gears?
Rgds emiel
Re: Raised pto
Posted: Sun Apr 12, 2020 8:54 pm
by mathias1
Emiel,
normally it's not the 1:1. but I will count the theeth to be sure.
I will install in on my Super 4, which is based on a 1963 super major (not new performance)
Re: Raised pto
Posted: Tue Apr 14, 2020 2:26 pm
by mathias1
Emiel,
18 and 24 teeth. So it's not 1:1, which is fine.
The 1:1 are really hard to find, as they only fit the new performance super majors.
Re: Raised pto
Posted: Wed Apr 15, 2020 8:04 am
by Old Hywel
Emiel,
Presumably that gives 540 at 1600 engine speed.
Re: Raised pto
Posted: Wed Apr 15, 2020 5:13 pm
by mathias1
Emiel,
Yes, that should be correct. If you look at the tachometer, you will see the standard pto is at 1200 rpm and the raised pto is at 1600
A little lesson maths: 1200 x 24/18 = 1600...
:thumbs:
Re: Raised pto
Posted: Wed Apr 15, 2020 7:59 pm
by Emiel
That’s good news. You’ve the right one then. I’ve one lying around but forgot whether it’s the standard or the npsm type.
Rgds emiel
Re: Raised pto
Posted: Tue Jun 09, 2020 10:09 pm
by mathias1
Some more pictures of fitting the raised pto:
New bearing fitted:
The nut has to be removed, but this bolt holds a spring and detent ball and should not be removed!
Did work well on the Vicon spreader, easy to attach the implement when you have the hydraulics active, and the pto disgaged!
I need to find the knob I ordered a while ago to finish this small project.
