Wheel weight bolts
Posted: Sat Apr 04, 2020 8:22 pm
by Willl
Evening all,
Does anyone know where in the UK it would be possible to obtain wheel weight bolts for a Major? I would need the 5 bolts to hold the starter weights and then the bolts to hold the rest, along with the tabs of course.
I've seen a couple of items on EBay but don't know what the quality would be like so would welcome any recommendations.
Ditto front weights..
Thanks,
Will
Re: Wheel weight bolts
Posted: Sun Apr 05, 2020 9:24 pm
by Timeee
Dear Will
Any decent fastener supplier should be able to help you, if you can give them the specifications which are below (taken from the parts list).
The rear Aux weight to weight bolts are 1/2" x 13 x 3 and 3/4in square head bolt. That is a UNC thread. Part no 23108 S The S indicates a plain finish.
The rear Wheel to weight bolts are 5/8in x 18 x 2 and 3/4 in Hex head bolt. That is a UNF thread. Part No 45804 S2 The S" indicates a Raven finish (black?) 5 each side
The front wheel weights are the same as the rear ones for aux weight to weight and are 1/2in x 13 x 2 3/4 in square head bolt. 4 each side. Part No 23108 S.
The reinforcement, or tabs as you call them are a special Fordson part only, so getting a set of them could be difficult. They fit snugly into the curve of the rear wheel Part No E27N 1077, so they were used on the earlier majors from 1946 to 1951 as well as the E1A majors. They were also used on the dual rear wheel sets.
Hope that is some help.
Tim E
Posted: Mon Apr 06, 2020 9:01 am
by Willl
Well that's a fantastic detailed reply, thank you Tim !!
Regards,
Will
Posted: Fri Apr 10, 2020 3:51 pm
by Emiel
Hi Will,
check out item number 1862 on pocock tractor supplies.
Rgds
Posted: Mon Apr 13, 2020 11:02 am
by Willl
Thanks very much Emiel I will certainly have a look at Pocock many thanks.
Please could somebody point me in the direction of the parts list as referred to by Tim? I need the specs for the front slab weight carriage bolts, I know this has been discussed on here previously and I remember reading a detailed reply by Brian, but now I've closed the page and can't relocate it. I need the bolts to be long enough for three front slab weights.
Thanks again,
Will
Posted: Wed Apr 15, 2020 9:55 am
by Timeee
Dear Will
According to the parts list there are 3 slab weights to a set. There appears to be 2 different types of bolts used for the 2 functions;
1. Front cross member to weight bolt 3/4"x 10 (UNC) x 3 and 3/4 inch long hex head bolt, 2 off.
2. Front weight bolt. 3/4" x 10 (UNC) x 4 and 1/4 inch long square head bolt, 4 off.
Tim E
Posted: Wed Apr 15, 2020 7:59 pm
by Willl
Thank you again Tim!!
Regards,
Will
Posted: Thu Apr 16, 2020 8:16 pm
by mathias1
I used to put 4 slabs combined with front wheel weights on mine to handle the big TSR 107 plough. I used threaded bars and dit cut them to length. Timee is right about the size: 3/4 unc.
Posted: Fri Apr 17, 2020 10:32 am
by Willl
Thanks Mathias - So if I go for the threaded bar option, which seems to be preferable on a cost basis, I just need 3/4 UNC threaded bar - high tensile steel - x 15 inches or so, and then cut them back to size?
Thanks again
Will
Posted: Fri Apr 17, 2020 6:20 pm
by mathias1
Willl wrote: ↑Fri Apr 17, 2020 10:32 am
Thanks again
Will
Yes, that is true, as long as you have genuine fordson weights. The ford 1000 ones do not fit, but you can make an adapter plate for it.
And you need some nuts too of course.
Posted: Fri Apr 17, 2020 10:11 pm
by Willl
Thanks Mathias, much appreciated, yes I have the Enfo weights.
Will
