Looking for 2" wheel studs
Posted: Thu May 28, 2020 10:00 pm
I'm replacing the wheel studs on my Fordson Major. Suppliers all seem seem to be selling only PN C5NN1N118J for this application. I bought these, but they are too long to be inserted through the hub from the back.
When attempting to insert these longer bolts into the hub, the axle's bearing housing interferes with aligning the bolt. The bolt won't feed through the stud hole at the angle forced by interference from the bearing housing.
The original wheel studs are 2" in length, not including the bolt head. The C5NN1N118J bolts are 2" 5/16" long, not including the bolt head.
Maybe I'm missing something to install these? Are others sliding the axle out to install new wheel studs?
Does anyone know where to get wheel studs in the original length?
I'm going to try using an abrasive wheel to shorten the bolt to solve the length problem. However, the un-threaded shoulder part of the bolt is also longer than the original which may cause the wheel nut to bottom on the stud shoulder before it clamps the wheel.
The shorter bolt inserts easily - the longer bolt can't be inserted into the stud holes - it hits the bearing seal housing which prevents it from being inserted.
As shown with the tape measure, the shorter bolt is about 2" 1/6, the new replacement bolt is 2" 5/16
