I have removed all pedals and brake linkages, I shall renew all pins, bushes etc, one thing is the shaft that goes through the backend is worn in a few places and I shall weld them up and machine them back down to original, my question is can I just pull the shaft out as long as oil is drained or would anything fall inside the backend?
Kind regards,
Kevan.
Brake pedal/clutch shaft
Re: Brake pedal/clutch shaft
You can pull it out. No problem.
Hi Emiel,
Thank you very much!
