Water
Posted: Mon Aug 24, 2020 1:20 am
by Billy26F5
We've been collecting water with Billy and our tank made by J Bargans. This time we didn't need our pump as we siphoned five tons of water down about 20 feet of hill to the tank.
Then we dumped it in to our watering tank.
Our second run was in the dark
Our next full load will need the pump.
Re: Water
Posted: Mon Aug 24, 2020 10:15 pm
by leeroy
What's the water needed for?
Nice tank!
Re: Water
Posted: Tue Aug 25, 2020 1:01 am
by Billy26F5
It's pretty dry here and our garden wants lots of water, so we always end up having to go and get it. It's made worse by the fierce sun evaporating quite a lot of it.
The only problem with the tank is that the fibreglass coating is exposed and shedding glass fibres, making it nearly untouchable. We're hoping to paint it in a transparent coating to prevent further loss of glass fibres.
Re: Water
Posted: Tue Aug 25, 2020 1:05 pm
by Heartless
if it is shedding fibers, painting is not going to help it much.. it needs a coat of resin to seal it up properly and for strength
then paint it.
Re: Water
Posted: Thu Aug 19, 2021 10:15 pm
by Billy26F5
Re: Water
Posted: Sun Aug 22, 2021 10:11 pm
by Billy26F5
Re: Water
Posted: Tue Aug 24, 2021 12:49 pm
by John b
If you made a bracket for the pump you could bolt it onto the front of Billy using the weight holes, it would save having to line the tractor and pump up every time to keep the belt on, and if the pipes are long enough you wouldn't have to un-hitch the tank. Be easy enough to remove it when not in use and also make a good winter project
Re: Water
Posted: Tue Aug 24, 2021 2:36 pm
by Billy26F5
We have thought of that, but our main problem at the moment is the belt, as it's a bit narrow. We hope a friend might find a much bigger old AC pump so we can have it belt driven too.
Re: Water
Posted: Tue Aug 24, 2021 2:46 pm
by Nickm
That looks good.
How much does the bowser weigh when you fill it up?
Looks pretty big. How steep a slope will the tractor cope with, with that in row?
Also, looks nice and warm there. Where is it if you don't mind me asking?
Re: Water
Posted: Tue Aug 24, 2021 2:47 pm
by Nickm
That was meant to say 'with that in tow' of course.
Re: Water
Posted: Tue Aug 24, 2021 3:59 pm
by Billy26F5
The tank (made by J Bargans, a local implement maker) takes 2.5t of water. I don't know just how steep it can be driven with, but pretty steep as Billy got water from quite far away years ago and there's a very steep hill on the way. It's been helish hot here (more than 40ÂșC), and very dry, which is why we're short of water now.
Re: Water
Posted: Sat Jul 16, 2022 10:52 pm
by Billy26F5
The water shortage is bigger than ever, and the garden is already demanding a fair bit, so the tank had to be emptied, but first our trailer had to be moved, Billy of course doing it all. You can see Super Billy's cab in the trailer, it will go in the barn for fixing once Super Billy is running (it can't at the moment as the engine is in the way).
In the background you can see Kenny, the spare buckets, a small trailer awaiting major repairs and the recently removed MF parts.
Re: Water
Posted: Sun Jul 17, 2022 8:55 am
by John b
Did you manage to get hold of an AC pump for the tank Sandy?
Re: Water
Posted: Sun Jul 17, 2022 10:07 am
by Billy26F5
Not yet John, unfortunately last year our belt deformed. meaning that now I don't think we can use it. Hopefully we won't need it just yet, but we'll see that fairly soon, in the meantime we'll see if we can find another one. The usual pump will do for now, the friend might well come to bring one some time as we told him ages ago that we're looking for one, although we hadn't got one to work until a couple of years ago (
viewtopic.php?f=2&t=8126) .
Re: Water
Posted: Sun Jul 17, 2022 7:40 pm
by John b
Very ingenious! Do you think gaffer tape would be strong enough to wrap round the shaft to make a high spot in the centre? It may stop the belt coming off
Re: Water
Posted: Sun Jul 17, 2022 10:07 pm
by Billy26F5
We tried it with insulating tape and a bit of old string buried in it, but it always came loose and covered the belt in dirt, eventually coming off the last time we used it last year. I think we really need to machine the correct shape on it, as it was very suceptible to any change, the other problem is that the belt streched on one side, making it impossible to use now. If we do have to go and get water before we get a better belt we'll try what we can, but I can remember just how difficult it was to keep on last time, which might make it take far longer. I'm hopeful we'll find one before that stage though.
Re: Water
Posted: Mon Jul 18, 2022 8:31 am
by mathias1
It's getting dry here also. The farmers have been doing hay all day.
I hope you get enough water for your garden.
Re: Water
Posted: Mon Jul 18, 2022 10:22 am
by Billy26F5
At the moment we're ok, but our tiny reserve isn't going to last long, hopefully we should have a belt by the time we need it. The garden is having a hard time anyway with the heat and that we're trying to make the water last as long as we can.
