Tractor Identification and Restoration Assessment.
Posted: Fri Oct 09, 2020 11:54 pm
Hello, Rod here, I'm new and this is my first post.
I am in Western Canada.
I am starting from the beginning with my first Fordson tractor. It's looks well used, and somewhat abused.
The hood badge reads Fordson Major Diesel.
To begin with I probably want to identify it as to a specific model, year of production, special features, modifications or alterations, and any atttached accessories.
Any advice is greatly appreciated.
Further to that I welcome any suggestions regarding things I might expect to encounter and what to look into and in what order. I am trying to figure out how to post pics so members can see it in case that is helpful.
Today I will try to post the image I made of the metal tag (data plate) which I found located on the engine side of the firewall, at the top. Is this possibly the tractor's serial number? Is this number useful to me?
I also found a number stamped on the engine block above the injection pump. I need to get a better picture of I it, I can't read the one I took. I am pretty sure that it starts with the letter S. A new picture will possibly take me a few weeks to get because the tractor is located at my homestead and I am presently some six hours drive away. I will be in Vancouver next week, after that I will be returning to my home in the central interior, where the tractor is at my workshop.
Btw, the rear wheels are seized fast and tight since I got it. They don't even hint of turning. I didn't see water in the transmission, but haven't checked the rear end yet. I am wondering if it might be the brakes, or something more serious...
The engine was hard to rotate at first, but in the end did yield with a pipe wrench on the front crank pulley shaft. I did only turn it a tiny smidge, I think it's free and I don't want to cause harm if there might be rust from sitting or such. I believe it has sat parked without operating for at least 4 years, if not ??? longer. The engine oil is dirty, but otherwise appears uncontaminated. The radiator smells like coolant inside, and not anything else.
Hopefully the pic of this data tag will help with identification, provided too that I can manage to post it here.
I have numerous other pictures from various angles as well if they might be beneficial.
Thanks in advance,
Rod
Thanks in advance,
Rod
