				Super Major, help identifying hydraulic remote control valve
				Posted: Mon May 17, 2021 7:12 am
				by Royjones
				Hello,
I've been using my Fordson Super Major for 20 years.
I inherited it 10 years ago when my father passed away, and I continue to do the same work he did.
Hopefully with a bit more understanding.
I'm wanting to properly replace the seals on this hydraulic remote control valve, but I'm having problems finding information on it.
Could someone please help me with identifying it so I can find all the correct seals. It has a constant weeping that I'd like to stop.
Thankyou, Roy.
				Re: Super Major, help identifying hydraulic remote control valve
				Posted: Mon May 17, 2021 8:24 am
				by Billy26F5
				You seem to have a very early top cover (25 Nov 1960). The DAR valve is an Australian one, I don't know if it's very similar to the Ford one or not.
Where is the leak? You might find something is loose, try getting everything reasonably tight before you dismantle anything, testing to see if that sorts it.
				Posted: Tue May 18, 2021 3:28 am
				by Royjones
				Thanks for the response,
At least now I know its a Double Acting Ram valve.
I'm certain it is leaking from an oring in the top selection shaft.
When we rebuilt it 15 years ago all we had was what you get in the as568 oring kits. needless to say they were not the correct sizes.
I will try giving it a clean up and tightening everything down again.
Roy.
				Posted: Tue May 18, 2021 7:56 am
				by Billy26F5
				Your DAR valve is not the Ford one, it's an Australian made equivalent. Don't overdo it with the tightening, if it doesn't seem to improve then you'll need a new o-ring.
				Posted: Tue May 18, 2021 2:58 pm
				by shepp
				See "Spool Valves" posted by "Brian" on Friday 15 November 2013.
				Posted: Tue May 18, 2021 11:52 pm
				by Billy26F5
				shepp wrote: ↑Tue May 18, 2021 2:58 pm
Here's the post:
viewtopic.php?f=2&t=5568
There's no exploded diagram of your valve though.
				Posted: Wed May 19, 2021 1:36 am
				by Royjones
				Thanks, I was just searching for it myself.
I'll have a good look though it.
				Posted: Wed May 19, 2021 5:55 am
				by Royjones
				Not a lot be be gleaned from that. but thanks for looking for me
				Posted: Thu May 20, 2021 10:39 pm
				by Royjones
				From that thread, it appears that my valve was also used on the 5000 but with a relocated lever.
