Hydraulic remote valves for trailers - Metal piping to replace the rubber
JLworld
Post by JLworld »
Hi I have a 1959 power Major.
It currently has a rubber hose that comes out the valve and bends round under the seat.
I would rather have a metal pipe coming out the valve and going straight out the back.
I believe that I should be a metal pipe?
I have attached some images of the current setup.
Where would you source the metal piping? Can I use galvanised water pipe fittings or can you get something that is made for the job?
Thanks in advance all
Will
JLworld
Re: Hydraulic remote valves for trailers - Metal piping to replace the rubber
Post by JLworld »
Hi Will
Yes there is a proper metal tipping pipe for the major, they do come up for sale on ebay occasionally. The only new ones i have seen for sale (agriline) are for the super major and they are different. As for using galanised pipe, i have seen it done but personally i wouldn't want to be sitting anywhere near one if they decide to go bang! Proper hydraulic pipe is seamless, galvanised pipe isn't and is only designed for water pressure
JLworld
Post by JLworld »
Thanks John I’ll keep an eye out on eBay
Will
Try railswood tractors, very helpful and have alot of used parts. They may have one
JLworld
Post by JLworld »
Sounds good I’ll give them a go
Just in case it's of interest, here's Billy's arrangement fitted by J Bargans in 2001.
and at work
Nice JCB in the background.
Hi Sandy, is that a super major pipe fitted to Billy? Both my power majors and the old diesel major have the pipes running under the cross shaft
J Bargans manufactured the pipe themselves, and as far as I know no other Majors have been there that recently, so this is the only one like that.
JLworld
Post by JLworld »
Hi all just seen this on eBay
https://www.ebay.co.uk/itm/Fordson-Hydr ... 890.l49286
Does that look like it?
Hi Will, thats an engine oil pick up pipe from inside the sump, definately not what you're after
That pick up pipe is not from a tractor either, could be a lorry or an industrial engine.
