FSMD change + gound to - ground
Posted: Tue Oct 19, 2021 3:25 pm
by FarmallM51
1962 FSMD with original generator & voltage regulator. All of my other tractors are negative ground. Can I just change this from + ground to - ground without changing anything else in the generator/regulator system? Thanks.
Marlin
Re: FSMD change + gound to - ground
Posted: Tue Oct 19, 2021 6:17 pm
by Hair Bear
No. Not difficult though. You'll need to 'Flash' the dynamo to repolarise it, and from memory the ammeter will work back to front. The starter will repolarise itself.
