Page 2 of 2
Re: 1959 Power Major | Injector Pump Lever
Posted: Mon May 02, 2022 6:15 pm
by John b
If you do remove the pump make sure you mark the couplers as it is possible to put it back together 180° out!
Posted: Mon May 02, 2022 6:34 pm
by JLworld
Thank you John
Posted: Tue May 03, 2022 10:55 pm
by Billy26F5
You shouldn't need to remove the pump for timing, an easy way to avoid mis fitting the pump is to have the pump marks aligned and the flywheel at the correct timing with the clamp bolt on the pump coupling underneath. Loosen the claw bolts as necessary.
