Page 2 of 2
Re: sump plug
Posted: Tue Jun 28, 2022 11:00 pm
by Billy26F5
Seems like a lot of work for slower draining! Definitely easier to replace than the 3/4"-24 UNS.
Re: sump plug
Posted: Thu Jun 30, 2022 9:59 am
by Arnie
Hi John b,
The pictures you posted look just like mine, do you think I could find one from a dealer anywhere.
I am glad it's not just my tractor, I have refitted the old one for now as I need to use the tractor but would like to replace it next oil change if possible.
Thanks for all your comments guys, I knew the knowledge base on here could help.
Cheers.
Re: sump plug
Posted: Thu Jun 30, 2022 12:37 pm
by Billy26F5
I don't think a dealer will have it, but it is worth a try. I would look around a scrapy, as if there's a Major sump it's quite likely to have the plug there. Ignore sumps with an inspection cover as those have the 7/8" UNF plug.
Re: sump plug
Posted: Thu Jun 30, 2022 4:54 pm
by John b
Nick, if you want to private message me your address i can post you that one, i've cleaned it up and it's not too bad, at least you'll have a spare then
Re: sump plug
Posted: Thu Jun 30, 2022 10:33 pm
by Emiel
Optionally you could ring agriline and ask them for the difference between their 5720 and 5720a sump plug for Fordson major. One would assume one of them is the right size.
Rgds emiel
Re: sump plug
Posted: Thu Jun 30, 2022 11:58 pm
by Billy26F5
Emiel wrote: ↑Thu Jun 30, 2022 10:33 pm
I don't think they're different, for some reason they think the sumps without an inspection plate on a Mk1 are different from the later ones when there was no Mk1 originally without an inspection plate. Both are E1ADKN-6730A, 7/8" UNF.
Re: sump plug
Posted: Fri Jul 01, 2022 5:28 am
by Emiel
I tink the description sucks. There should be a reason they have two different order numbers.
Re: sump plug
Posted: Fri Jul 01, 2022 8:20 am
by Billy26F5
I agree, but I have known them to get things wrong (quite badly), so it's probably better to ask for the thread first.
Re: sump plug
Posted: Fri Jul 01, 2022 4:46 pm
by Arnie
I did call Agriline, they sent me both, and both are wrong , I had a conversation and emailed pictures with them in my caliper showing the size, they still sent both that were incorrect size and thread, have them here to return, not any help at all.
Re: sump plug
Posted: Fri Jul 01, 2022 7:20 pm
by Billy26F5
Arnie wrote: ↑Fri Jul 01, 2022 4:46 pm
Were they both 7/8" UNF? If not they'll have made a bigger mistake.
Re: sump plug
Posted: Fri Jul 01, 2022 7:45 pm
by Arnie
Yes they were both 7/8 with a course thread measuring 21.4mm one with a 28mm head one with 32mm head part no 5720 and 5720A both no use.
Re: sump plug
Posted: Fri Jul 01, 2022 8:06 pm
by Arnie
I would add the pictures but I can't work out how to add them to a reply. Sorry
Re: sump plug
Posted: Fri Jul 01, 2022 10:15 pm
by Billy26F5
For pics try this:
viewtopic.php?p=53955#p53955
I don't understand why there's the difference in head size, but the original plug was probably neither of those. 7/8" should be 22.225mm.
