New oil pump for diesel engines
Posted: Mon Feb 02, 2026 10:20 pm
Most of you will have seen that the oil pumps available today are 528E-6600 and slightly modified E1ADN-6600B, with shaft 528E-6609 and a gear that is like E1ADN-6652 (1/2" wide) with oil holes like 528E-6652. But I found an Ebro pump available new here:
https://www.fridayparts.com/engine-oil- ... uper-major
This one is E1ADDN-6600C (not as it claims 528E-6600), and it was only ever available from Ebro. The only difference is the drive gear, E1ADDN-6652C instead of 528E-6652. A perfect pump if you want a late engine in true original condition (only ever used after roughly 08B-752791).
