Will the intake manifold from a early FMD fit the SMD head?
Will the Major front wheel weights fit the Dexta front wheels? Both are 16 inch
? FMD-SMD:Specific Parts interchange
Just to add to Kev's post. On the early Majors the ports themselves were staggered too!
Wheel weights; yes, they also fitted all the '000nd series, MF and Nuffield. I have Ford weights on Nuffys wheels.
To late, its packed on the truck ready to go back with me!! Just limited on weight with this little Chev 1/2T C-10 250 IL6 I have to haul with on this trip. After all the Chev is a $100 buy off Craigs List Vancouver. Just didnt want to add the last straw to it!:(
Will have to see If I make it back home without problems. I have only burned 1 tank of gas, city driving,
in it before I hit the pavement! I got a load of machine shop machines on!
JC wrote:Its kind of confusing, isn't it? On the early heads, the bolts were in a straight line, but the ports were staggered. On the later heads, the ports were in a straight line, but the bolts were staggered.
