differential
differential
hello,would it be possibal to fit a lower ratio diff from another fordson or any other tractor in the backend of a dexta to get abit more road speed.many thanks
Re: differential
How fast will it go fella ??. In 6th flat out my standard Dexta just touches 16mph according to my Sat Nav. i thought that was pretty fast for an older tractor. maybe yours needs a slight adjustment, as to the Diff , i dont know. Jim.
Fordson Dexta, Barn Door Technology at it's best.
Re: differential
Hi,super does 25mph,I was just wondering if there was a way to get abit more by changing ratios somewhere.cheers
Re: differential
25mph, wow how do you manage that.??? must have a turbomstainton wrote:Hi,super does 25mph,I was just wondering if there was a way to get abit more by changing ratios somewhere.cheers
Re: differential
Add a few more revs to the engine and........... put on some Super Major rear wheels!
Zoom,
Les
Zoom,
Les
Re: differential
i carnt workout why your dexta is so slow,we have 4 and the early ones are higher geared,they do nearly 30mph, every dexta ive seen on a road run have been able to do 25-30mph,yours is maybe the golf course model which were lower geared than standard
Re: differential
I have the same issue. need to by new tires anyway so was thinking of changing from 10-28 to a larger size like 12.7-28 should increase road speed and traction.
Regards,
Regards,
