Dexta -60 project
dexta64
Re: Dexta -60 project
Post by dexta64 »
Dexta Owning privilege.
Fordson Dexta Model : 1964
Engine No: 154**49
Serial No:9007**
dexta64
Post by dexta64 »
Engine No: 154**49
Serial No:9007**
Broadspeed
Post by Broadspeed »
^nice tractor :)
Bensdexta wrote:
Broadspeed wrote:It is the locking lever for trailer hitch.
Haven't painted the hitch yet, so it's still missing :)
A close-up photo when it's finished would be great! :D
Here's few pics of it. The hitch stays up, even the linkage goes down :) You can release hitch by pulling that long lever You see on the left
Linkage up
Linkage down
Dexta -60
Dexta Special -64
dexta1960
Post by dexta1960 »
Do you have a plan design for your foot throttle pedal thanks
dexta1960
Post by dexta1960 »
Do you have a design plan for your throttle pedal
Post by Jerry Coles »
Hi Broadspeed
Notice you have adjustable steady bars on your linkage - your own design or were they on the tractor originally?
4 Dextas
Bath
Somerset
UK
Broadspeed
dexta1960 wrote:Do you have a design plan for your throttle pedal
Unfortunately no, I made it straight from scratch :( But the idea You can get from the pics on page 2 :)
Jerry Coles wrote:Hi Broadspeed
4 Dextas
Bath
Somerset
UK
Hello
Those are universal steady bars. Available in almost every farm shop in Finland
http://www.ikh.fi/Varaosat_traktorit_ja ... 2_tid14679
Dexta -60
Dexta Special -64
Bensdexta
Post by Bensdexta »
Broadspeed wrote:Those are universal steady bars. Available in almost every farm shop in Finland
Can you operate with one or both their pins removed, to give more lateral movement of the linkage, eg for a harrow?
Although, I see you have no check chains, so you must use the steady bars?
Happy Christmas! :beer:
Broadspeed
Yes, You can operate one or both pins removed. Or both pins on place, depending what You are doing :)
I noticed that I don't need check chains with this type steady bars in use
Dexta -60
Dexta Special -64
Bensdexta
Post by Bensdexta »
Sadly those steady bars don't seem to be available in England.
Broadspeed
Quite suprising, because they are so handy :shock:
Anyway it is easy make those kind of steady bars yourself. Couple pieces tube with different diameters and drill few holes to them :D
Today assembled snow chains and noticed that Agriline ignition/light switch wont work after couple months use :evil:
Where to get new one with better quality?
Dexta -60
Dexta Special -64
Bensdexta
Post by Bensdexta »
Broadspeed wrote:...and noticed that Agriline ignition/light switch wont work after couple months use :evil:
For that reason, I fitted separate light and 'ignition' switches like a Super D.
Got an original Super D light switch and fitted a Hobbs ignition switch on the RH side of the lower dash, as per Super D. See here:
http://www.fordsontractorpages.nl/phpbb ... 22&p=10197
:wink:
Broadspeed
Yes that's one choice. But I would like to keep this original style switch :)
Dexta -60
Dexta Special -64
Bensdexta
Post by Bensdexta »
Does it have a universal joint at the front under the axle?
And the standard bracket under the axle is replaced by one on the steady bar? :scratchhead:
Broadspeed
Yes the standard bracket is replaced with ones that come with steady bars. Needed a little bit modification to fit, but works wery well now 8)
Dexta -60
Dexta Special -64
Bensdexta
Post by Bensdexta »
Broadspeed wrote:Yes that's one choice. But I would like to keep this original style switch :)
In fact from December 1961 standard Dextas had separate switches, like the Super D, so I don't feel guilty! :wink:
Broadspeed
Heh :D
So the light switch without ignition switch works better? I mean the reproduction ones?
Dexta -60
Dexta Special -64
Bensdexta
Post by Bensdexta »
Broadspeed wrote:So the light switch without ignition switch works better? I mean the reproduction ones?
Can't speak for sure about the repro switches as I got an original one, but my guess is yes, because the water can't get down the middle as there is no key hole. Also I packed my light switch with silicon grease to keep water out.
Pretty sure Fordson changed the switch design to avoid the water problem.
Broadspeed
Maybe I try one more time with original style switch. Just try to keep it dry better :)
Dexta -60
Dexta Special -64
Bensdexta
Re: Dexta Stabiliser Bars
Post by Bensdexta »
Just looking at your Stabiliser (Steady) bars again:
Your adjustable bars go from under the rear axle to the lift arm attachment half way along the lower arms (where check chains would normally attach), unlike the standard stabilser bars which go from under the axle to the rear end of the lower arms.
This means that with your Stab bars, the lower arms are subjected to sideways bending due to side loads from the implement, which doesn't happen with standard bars.
However it looks like you have strengthened your lower arm by welding on top/bottom flanges to resist the sideways bending, but only on the LH arm? Does the lower flange you've added underneath the LH arm, run the full length of the arm?
So I'm just wondering if the standard Stab bars aren't actually a stronger design afterall - I wouldn't like a kink in my lower arms? :( :scratchhead:
Broadspeed
LH arm is strenghtened by some previous owner. Looks that it has been in two pieces.. So that's why the LH side looks different.
Standard steady bars would be better. Haven't ever seen a picture of originals, so does anyone have a pic :?:
Dexta -60
Dexta Special -64
Saw a pair of these steady bars for sale at the Tractor show last sat at the Bath & West showground.
Spoke to the vendor, they are off a Ford 3000?. He wanted £300!
Bensdexta
Post by Bensdexta »
Just bought a pair of these long adjustable bars from A..line, at £15 a side. http://www.agrilineproducts.com/Catalog ... 39f4d9956f
They go from the pin under the axle to the implement lower hitch pins, so a stronger set up than the short bars. The lower link arms are quite flimsy in sideways bending.
And also a pair of stabiliser chains with adjustable turnbuckle, for use with my harrows in place of the bars. Will post pic later. I did need to straighten the angle of the link pin eyes on the chain to match the geometry - easily done in a press.
Mark
Post by Mark »
Broadspeed, I've never seen anyone put heavy vertical chains on there tractor before. How do these help? To keep your tractor from lifting to it's maximum height?
See ya
Mark
Broadspeed
Mark wrote:Broadspeed, I've never seen anyone put heavy vertical chains on there tractor before. How do these help? To keep your tractor from lifting to it's maximum height?
Those chains are for towing hitch lifting. See these pics:
Linkage up
Linkage down
Image[/quote]
Dexta -60
Dexta Special -64
