Hydraulic remote help
Beauwh
Post by Beauwh »
I wanting to add a hydraulic outlet to my super dexta so I can use a haybine that has a single acting hydraulic cylinder. This is what Im working with. Im just not sure what needs to be done to make this work. Can someone point me in the right direction? Thanks
dexta roadless
Re: Hydraulic remote help
Post by dexta roadless »
It's quite easy. Take out theplug you have marked "1" and screw in a 1/2" pipe connection of some sort. when you use it, pull out the knob you have marked 2 activate the external service and use it by operating the main handle.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
Beauwh
Post by Beauwh »
So for a single acting hydraulic cylinder thats all I need to do? I dont need a return line?
peter2
Post by peter2 »
another question, because the picture shows it very good: How is the valve (Nr. 2 in the photo above) dismantled, which switches between 3pt linkage and the external pipe? It looks similar to that on my super major, but mine does not move.
Can I turn the big round cover?
Peter
1963 Super Major
Post by Jerry Coles »
for earlier Hydraulics these pics might help:
http://s1106.photobucket.com/user/oldtr ... t=3&page=1.
Beauwh
Post by Beauwh »
To my surprise the the aux knob works good. I expected it to be froze being that the knob is missing. I just put a washer and nut on the threads to make it easier to pull. Can anyone tell me how to check the hydraulic fluid level?
Bensdexta
Post by Bensdexta »
Beauwh wrote:Can anyone tell me how to check the hydraulic fluid level?
http://www.fordsontractorpages.nl/phpbb ... f=3&t=1715
http://www.yesterdaystractors.com/cgi-b ... k&th=64727 :wink:
Bensdexta
Post by Bensdexta »
dexta64
Post by dexta64 »
Fordson Dexta Model : 1964
Engine No: 154**49
Serial No:9007**
dexta64
Post by dexta64 »
Engine No: 154**49
Serial No:9007**
EddieJ
Post by EddieJ »
My web site hosting has changed, its no longer with moonfruit but you can find the same information here:
https://www.fordsonsuperdexta.co.uk/Hydraulics
Currently updating all my links on FTP Forum
