i cleaned up the top of the pistons and the top of block, iput a smear of clean engine oil
in the bores and the piston head and the block , to keep the the bits from rusting
will i have to clean bores with white spirit before fitting head or just leave the engine
oil in for lubration, also manual says smear front and back of gasket with jointing compound
what would be best for this, any other things i should do be fore fitting
![Does this make sense? :scratchhead:](./images/smilies/headscratch.gif)
thanks in advance
