Not original starter
123Dexta
Post by 123Dexta »
I just bought my very first and best Dexta. 1961.
I realised that a lot of changes had been made. I plan to restore it as close to the original as possible.
So far, I see a new starter and am missing the control box.
Do I need the control box, or It's not necessary anymore?
And there is no more throttle lever to the starter, I just need to turn the key.
Image[/img]
Re: Not original starter
123Dexta wrote:
Thu Aug 28, 2025 7:05 pm
Couldn't see your pic, you only need to copy the link, no need to add the image code as the link already has that in it. That looks very different from std, to the point of being a bit concerned about it fitting at all. You need to replace the alternator and starter with original items, being all Lucas, a M45G 26143N starter, a C39P2 22259D dynamo and a RB108 37396 regulator. Modern alternators use an internal regulator, but it's still required. You'll also need to find a starter lever and rod plus pins (1/4" OD 25/32" long) lever fixing bolt and split pins (1/16" OD 3/4" long). Can't see enough to say more. You might well find you still have the regulator in its location, in the dash. More pics will help on a more general basis on various details.
123Dexta
Post by 123Dexta »
Thank you Sandy.
More pictures will be provided later.
123Dexta
Post by 123Dexta »
Sandy, it's a very complicated operation to attach the photo. Can you show, please, what the image link looks like?
I am trying to click the image icon on top of the text box, then I insert the link in between the square brackets.
But nothing is working.
My example: Image[/img]
123Dexta wrote:
Fri Aug 29, 2025 3:21 pm
Not sure you've seen this but check it anyway: https://www.fordsontractorpages.nl/phpb ... 955#p53955 You don't need to use the image icon with this, it works by itself.
Looks like the bracket for the starter lever is broken, so even more difficult but still possible to fix, either weld it up or fit a second hand part that is better.
Why bother? The starter shown appears to be a geared model, giving much improved cranking speeds, and easier starting.
You’re missing bits anyway, and original isn’t always better.
As a caution, your Dexta is now likely to be 'negative earth'. No biggie, just something to be aware of.
It's a question of reliability or aesthetics.
What I'm seeing are reliability type upgrades. The p3 was always a good starting engine so I would suspect when the time expired original needed replacing, a geared starter wasn't much more expense and reduces stress on other 60+ year old components. If it were mine I'd consider leaving it alone but fit a dummy lever to the dash just to look right.
I'd keep the alternator without a second thought. An alternator system doesn't need a control box. The charge rate is probably a 50% or more increase compared to a dynamo, again a reliability upgrade. But, the visual difference between alternator and dynamo is quite obvious. On the showfield, a rivet counter with a pocketfull of jam sandwiches and zero understanding of A-V-O will joyfully point out to anyone bored enought to listen that the alternator is wrong.
Most of all, remember it is your tractor, no one elses, get out there and enjoy it.
My opinion, like others, are just opinions! :)
If it works, leave it alone.
I'm not a fan of these things, I find the original parts quite capable of doing their job, and Dexta's are never great starters anyway. Using the primer and heater correctly will help a lot. The alternator will incorporate a regulator in it so it needs one too, but it's different from the std one that is in the dash. I doubt many people who make such changes will bother to remove the original regulator, and its location in the dash makes it easy to overlook. Original is original, but it's up to you to decide what you do with yours. I always recommend original but that's just me, it will make everything easier though, as you have all information in manuals as specified. When changes are made it can make this very confusing, and I can say that if you then have an issue with the electrics it can drive you round the bend trying to find what wires do what. Getting spares can be tricky too, to the point of impossible for certain modified parts; original parts can be tricky too but at least it's not too hard to find the part numbers for them and then you have an idea of what to look for.
123Dexta
Post by 123Dexta »
Thanks to everyone for the accurate and helpful advice. I think I’ll stick with the new starter, and thanks for the tip about the dummy lever rod)))
There’s no control box on the panel, and Sandy was right – you can always find the old wiring diagrams, but it isn’t easy to figure out how the new wiring has been done.
Yes, the negative is currently connected to earth, like in regular cars.
Unfortunately, there are still a few quirks. I don’t quite understand how the stop button is wired. The previous owner converted it into a pedal. As long as you keep the pedal pressed, the engine runs – release it, and the engine shuts off.
That's not a good arrangement. I would return to a std stop cable, then it'll be easier. Quite keen to see pics of this odd thing, I can only presume it was a deterrent of sorts or something along those lines. Can't show you a pic as I don't have a suitable one for a pneumatic governor (if you have a minimec I can, but that didn't come in till engine 1530251).
Yes, more pics please!
Do I see a loader frame? Which pedal do you need to keep pressed to keep it running?
123Dexta
Post by 123Dexta »
A few additional photos. The loader is from 1961 and was made in Germany. There’s a plate on it stating 1961.
https://postimg.cc/d71q3ZBv
https://i.postimg.cc/d71q3ZBv/front.jpg
https://postimg.cc/Ty4TD27b
https://i.postimg.cc/Ty4TD27b/loader2.jpg
https://postimg.cc/k2wJ7vWf
https://i.postimg.cc/k2wJ7vWf/pedal.jpg
https://postimg.cc/kBQMpmGr
https://i.postimg.cc/kBQMpmGr/pedal-wire.jpg
The previous owner (or owners) replaced the Stop button with a pedal. To start the tractor, the pedal has to be secured with a wire. To stop the tractor, you need to release the wire from the pedal. It’s a very primitive and inconvenient solution. The plan is to remove all the unnecessary bits and restore the Stop button. But there’s a nuance.
Originally, to start the engine, the stop-control cable on the fuel pump wasn’t pulled.
Now it’s the opposite – we pull it to start the engine and release it to stop the engine.
Maybe somebody can explain how to fix it to the original condition? Do I have to flip the stop-control shaft?
It’s very cramped in there, and it’s difficult to take a decent photo to explain properly.
That looks like a foot throttle. Some more pics of the linkage and the injector pump and intake manifold would help with the details. I understand your issues with the loader (nice loader by the way!), but without seeing this I can't help you much as I don't know what you're starting with.
123Dexta
Post by 123Dexta »
Another question.
What is this for, and how can I use it?
These front double axles I marked blue.
Never seen them before, not original. They're not in a good place either, as they make timing much more difficult.
I wonder what the engine was in originally? The extra pulleys suggest a 'Bowman' style raw water marinised conversion, but the pedal arrangement could have been a 'dead mans handle' for a narrow gauge loco - all very intreaging.
Those are both good points, but odd for a Dexta. On a Major it would be more usual. An odd dead mans setup though, it usually locks the brakes on on most vehicles.
123Dexta
Post by 123Dexta »
Thank you.
So, do you think the engine is not original?
The previous owner gave me a second engine. He was 100% sure that I could replace the existing engine easily, but I see big differences between the old engine and the spare one.
The tractor is working, but the engine block has cracks in it. It’s very sad to see.
I have ordered some liquid sealers for cracked engines and epoxy metal glue. I really hope I can solve the leaking problem from both the inside and the outside.
Here are the photos of the spare engine:
I don't know about your current engine without serial and engine numbers but it looks suitable. The spare engine is not, it's a D3.152, similar to that in the MF135 but looks like an industrial one. They're not swappable without lots of conversion work. Pitty about the cracks, you'll just have to find a replacement block unless you're very lucky and find a very expert welder. See what you can do with the stuff you've got in the meantime but do look around for a block (only from Dexta's, never MF or other Perkins versions).
123Dexta
Post by 123Dexta »
Thank you Sandy.
I will try to find the number on my current engine. Is it on the left side, near the Simms?
It's on the block just behind the coolant inlet. The serial number is on the bell housing flange next to the timing inspection cover.
123Dexta
Post by 123Dexta »
I think the number is: 14997164
123Dexta
Post by 123Dexta »
Some other number too:
It looks more like 1499710 to me. A better clean and pic will confirm that. The other pic is the gearbox casting code, the serial number and other casting codes will be very helpful to identify this.
123Dexta
Post by 123Dexta »
I checked the engine number, and it's exactly 1499710
Here is another number: 09B701365
