![Sad :(](./images/smilies/icon_sad.gif)
![Embarassed :oops:](./images/smilies/icon_redface.gif)
I fitted an oil pressure sensor and light last winter, having previously fitted a new temperature gauge in 2007. The gauge never moved off the rest post - just like a previous one I fitted (they worked in a boiling pan of water). I read somewhere that these replacements gauges were unreliable so gave up on them.
Up until now everything has been OK with the oil pressure and she doesn't overheat or use water. I did a 40 mile road run a few weeks ago and the light was off all the time, except for absolute idle when really hot, which I accept as normal. The temperature gauge was just acting as an ornament.
I mowed 7 acres at the weekend with my old Hayter 3 rotor mower (3rd gear low ratio in whispy grass), like I do every year. Two things happened; after about 3 acres I noticed the temperature gauge had climbed and was holding in the orange band, also the oil pressure light started to flickered. After leaving her to cool down I mowed again for another 2 acres had to pause and so on.
I will change the oil as that is due - It was a very hot day - the mower gearbox seems as looses as it's always been.
Am I missing something or am I asking too much of the old girl and have I just been lucky in the past
![Question :?:](./images/smilies/icon_question.gif)
Alan
