Though that I would not let the rain put me off trying Dotty on the plough.
I have a Ferguson single furrow deep digger that I borrowed, so I started to adjust the wheels to the correct width. It was then that I got my first surprise! These wheels are 100% water loaded, I got quite a shock when it came off the wheel studs and I struggled to move it.
Eventually I got it safely leaned agains Nuffy and changed the disc position. All the rim bolts came out nicely and there was even an antipodean mouses nest between the brake drum and the wheel dish. Got the other side removed and this one back in its place. So far so good.
I got the next one leaning against Nuffy and I struggled a bit to get the rim bolts undone and out but managed it eventually. Then found I could not remove the dish from the rim as some kind person had welded them together at every lug!
At this point it started to rain hard too!
Luckily I have the same sized wheels on Harriet Ferguson and she really needs more weight on the back for loader work so I have fitted the welded up wheel to her and the Ferguson wheel which can be adjusted is to be fitted on Dotty. Now I will have to find a Dexta wheel dish for it otherwise it will look strange. better still, find two and the Harriet will not look odd too!
Once I have got her back on four wheels it will be down to the field and we will see how she goes on the plough.
