pump change over
pump change over
ihave seen this covered somewhere before but cant seem to find it , mybe someone can help ,iwould like change a mec/ pump for pn/ type on dexta ,i am able to sort out linkage etc but my ? is how could it be timmed without later type flywheel, or does anyone know of a way around this, Gerry
If installing a flywheel having only the 26 deg BTDC timing mark, lokate and stamp the 20 deg BTDC in a measurement at 2,7 inches from the TDC mark measured along the circumference of the flywheel. The total between TDC and the 26 deg mark is 3,52 inches, so maybe it is easier to measure 0.87 inches from the 26 deg mark.
Easy but maybe not through the inspection hole
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
Re: pump change over
May I ask why you want to revert to the earlier pneumatic governed fuel pump?GERRY wrote:ihave seen this covered somewhere before but cant seem to find it , mybe someone can help ,iwould like change a mec/ pump for pn/ type on dexta ,i am able to sort out linkage etc but my ? is how could it be timmed without later type flywheel, or does anyone know of a way around this, Gerry
All the best,
Ah ha, I had it the wrong way roundGERRY wrote:Hi Bensdexta . im trying to change from pn/type to mec/type/ . i have had alot of problems with the pn/ type with haunting , ihave changed the dif... an done all the pipe checks etc but still having problems. i have a spare mec /pump so thought i will use it ,no more worries about haunting , Gerry
You want to upgrade to the later mechanically governed fuel pump.
I wonder why you've had hunting problems with your pneumatic pump?
Let us know how it pans out.
Thanks,
Hi i just thought i would give an up date on the pump change over ,i fitted it in and timmed per the 22/ 23 mm above spill mark on old type flywheel . after alot of bleeding an messing about with the pipes , ihad to make new ones from lift pump to filter and from filter to injection pump also had to alter from tank to lift pump , ieventually got her to run , some minor leaks to sort yet but she is running sweet, ill have to get the throttle linkage sort out yet but a least the pump is good and and she running good an no more haunting
Gerry
