Dexta oil
warwick
Dexta oil
Post by warwick »
where can i get hold of 20w/30w oil for my dexta and do i use this grade oil in the hydrulics ? I have some 10w/30w will it do.Thanks
GERRY
Post by GERRY »
HI warwick, the problem of oil comes up from time to time , there are afew posts on here but i could not find the recommended oil and after going through all the serching i ending up useing 15/ 40 castrol power plus all through engine an back end , i dont know if this is right but so far i havent had any problems.ii think if they are near you that morris stores might have the recommended oil Gerry
warwick
Post by warwick »
Hi Gerry Thanks for reply will give it a try
Post by Bensdexta »
There is Brian's sticky thread:
http://www.fordsontractorpages.nl/phpbb ... php?t=1012
There are quite a few threads on oil types (when the search facility is working :( )
