Small Baler
Small Baler
Hi has anyone ever used a small baler on a dexta ? I have 4 acres that we make hay on but its had finding someone to bale just when you need it . The fields are on a slope so could weight be a problem ?
Baler
Yes folk do bale with a Dexta. Here's a thread about it:
http://www.fordsontractorpages.nl/phpbb ... .php?t=529
All the best
All the best
Hi there check out the photos on our web page at:
https://www.fordsonsuperdexta.co.uk/GeneralPhotos
Theres a couple of our SuperD pulling a MF baler - cant remember the model number but it used to do around 15 acres a year on quite hilly terrain
After we have finished the dexta rebuild the bailer/turner is next
pottyperkins
To really answer that question would need a bit more information
How steep is the field
How much tread have the tyres got, Have you water balast in the tyres
I dont think there is any problem with powering a baler horsepower wise, are you baling up or down the steep parts,
Balers are quite well balanced so there is very little weight to give traction to your tractor, so climbing steep slopes without spinning and braking decending them are the problems
i havent had problems baling with a dexta on steep hills its all down to what gear you use, if you select the right gear for the job going down hill the engine does the work for you, if it is a non live drive tractor you will need to fit a over run coupling so you can change gears easily and stop when you need to without the flywheel pushing you along.
along time ago not many tractors were live drive and they ran balers off them.
as i said above the right gear for the job is more important.
James
James
pottyperkins
Hi james
What gear do you find works best for bailing in a good crop
I havent used my dexta to bale with, but may give it a try
We also had a neighbour to do our baling with a 72hp leyland. but he retiered, so i bought our own baler but we have had 3 poor summers so havent done much since the dexta was finished.
The Swanndri Guy
Warwick, many years ago I used to use my Super Dexta with a IH 440 baler to bale hay, useing second and third gear, without any problems.But useing a IH B47 might be a better match for a Dexta as they are slightly lighter and smaller.As you only have 4 acres to do, providing its not to steep, it should not be a problem.Your bigest problem will be getting teenagers to pick up the hay bales after you have baled it!
TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
pottyperkins
My baler is a mf 20 similar to eddiej baler on this website,
http://www.superdexta.moonfruit.com/#/g ... 4535950669
The manual for it states recommened pto speed is 540 to 610rpm, it certanly bales better running slightly faster than the normal 540 pto speed.
i think its slighty to heavy for a dexta on very steep ground
Roadless63
