dexta pulling to one side
Posted: Sat Apr 03, 2010 5:03 pm
by GERRY
Hi all, I have been out turning over a bit of land when i got the dexta boged down , had to get her pulled out , since i have found that when i am driving i have to hold the steering wheel tightly or the wheel will spin voilently to left , before this i could let go of wheel and she would drive in a straight line without any problem, i cant see anything visibly wrong , any ideas what i might have damaged, Gerry
Posted: Sat Apr 03, 2010 6:08 pm
Sounds like you have bent a stub axle. Check that your marks on the axle still line up when the wheels are straight ahead.
Other problem could be brake sticking.
I tried to plough some land for potatoes yesterday. Nuffy spent more time spinning than ploughing.
Just going to have to leave it alone a while longer.
Posted: Sun Apr 04, 2010 1:04 pm
by GERRY
Hi Brian this bad weather sure does make things enjoyable, got her in an checked stubs they seem to be ok i re adjusted the toe in an what ever was wrong it must have cured it . took it for atest and shes running perfacto again , now to find another swamp
GERRY
Posted: Sun Apr 04, 2010 9:24 pm
by Jerry Coles
If you got bogged in could some mud/soil have got into the rear brake drum on one side causing it to bind?
Posted: Mon Apr 05, 2010 11:48 am
by GERRY
This could have been apossiblity Gerry becuse she was right up to the axels . what ever was causing it after i reset the toe in , imust have relased atwist or pressure of sort on track rods, its working prefect,I supose ill never know
