Posts: 2666 Joined: Mon Sep 15, 2008 12:59 pm
Post
by Bensdexta » Tue Apr 13, 2010 3:39 pm
According to the parts list, the pneumatic fuel pump should have a gasket between pump & timing case, see item 94:
Where can I get such a gasket?
Or is it a case of make your own? If so how thick should the gasket be?
Thanks for your advice,
Tubal Cain
Site Expert Team
Posts: 418 Joined: Wed Apr 16, 2008 8:47 pm
Post
by Tubal Cain » Wed Apr 14, 2010 7:35 am
Good practice dictates that a gasket should be as thin as possible subject to the condition of the mating faces. There are exceptions to this rule where the gasket forms a spacer such as cylinder head gaskets, which doesen't apply in this case.
A gasket cut from a Corn Flakes packet will be quite adequate or you could use one of the liquid instant gaskets which are available.
Gerald
Post
by Bensdexta » Wed Apr 14, 2010 6:19 pm
How does 0.4mm (1/64") sound?
This seems to be a standard thickness.
Tubal Cain
Site Expert Team
Post
by Tubal Cain » Thu Apr 15, 2010 7:25 am
That is about as thin as you will get with gasket paper and will be suitable for this application.
Gerald
