Towing hitch (hook)
coroflor
Towing hitch (hook)
Post by coroflor »
Hi Everybody,
I have a fordson Dexta from '62. I am looking for a towing hitch (hook)
like this
from here: http://www.fordson-dexta.de/downloads/dextaetxl.pdf
page 158
Or like similar with this one from here:
http://www.mijnalbum.nl/Album=CBWTHOEL
Can anyone tell me from where I can buy something like this compatible for my DEXTA? Or can give me an advice how to make it (dimenson, etc)?
Thank you!
Hitch
Post by Bensdexta »
Or like this:
Image[/quote]
If so email Stefan on fordson-dexta.de
All the best :wink:
coroflor
Re: Hitch
Post by coroflor »
Bensdexta wrote:Or like this:
All the best :wink:[/quote]
Thanks for info! Your version is much better!
I will try to write him!
Many thanks!
Re: Hitch
Post by Bensdexta »
coroflor wrote:Hi,
webmaster@fordson-dexta.com
Stefan is very helful :wink:
Mark
Post by Mark »
Welcome to the board, I believe you are the first Romanian to join our tractor forum. Send us some pictures of your tractor.
See ya
Mark
coroflor
Post by coroflor »
Mark wrote:Welcome to the board, I believe you are the first Romanian to join our tractor forum. Send us some pictures of your tractor.
Hi ,
Thank you, Was a pleasure to read the yours helpfuly post from a while.
I bought in 2005 two tractors from Denmark one Ford Dexta and one TEA20.
On the Dexta I change entire cillinder kit, because one of the piston crash!
The tractors are on my parents on vilage and are use for land working.
I found just some to make an idea :)
1. Someting which some of us see just in pictures or old stories :lol:
2. TEA
3. DEXTA
I will make some pictures in the weekend!
Comeback with serials and new pictures soon!
pleasant weekend for all!
GERRY
Post by GERRY »
Hi i have ahitch on my dexta it is in two bits , there is a frame which bolts to bottom of tractor with the 4 bolt holes , there is also two holes that along pin goes through, the main hitch swings on this and is carried up and bolts to rocker hole under seat with another pin an this can all be taken off by simply pulling out the pins, the belly frame is made with 2 inch flat iorn, the hitch bracket is of same with actualy hitch made of 3 inch flat about 10mm thick . hope this is understandable. Gerry
coroflor
Post by coroflor »
GERRY wrote:Hi i have ahitch on my dexta it is in two bits , there is a frame which bolts to bottom of tractor with the 4 bolt holes , there is also two holes that along pin goes through, the main hitch swings on this and is carried up and bolts to rocker hole under seat with another pin an this can all be taken off by simply pulling out the pins, the belly frame is made with 2 inch flat iorn, the hitch bracket is of same with actualy hitch made of 3 inch flat about 10mm thick . hope this is understandable. Gerry
Hi Gerry,
Thanks for description. A small picture will complete your words!
Any idea from where I can buy something similar with your description?
john.n
Post by john.n »
does a fergie hitch line up with the bolt holes in the underside of the backend?
GERRY
Post by GERRY »
GERRY
Post by GERRY »
Hi coroflor this a picture of the hitch on my tractror an another of ahitch off my other dexta, ihave not been ableto get photo of the part which screws to bottom of tractor but this should give you an idea, a tow bar off a car has been welded to first picture , ill have to cut it off ,it was just for a tempory job ihad to do,its not part of the tractor hitch. Gerry
