Massive Crack
Massive Crack
We've just found a five inch long crack on the side of the engine between the two core plugs. Is it possible to weld such a big crack and if so, where do you find somebody to do it. It's not your ordinary welding job, is it?
Sorry to hear that
You may be able to weld it, or metal stitching may be the permanent solution.
A quick google brought up these folks who weld cast iron:
http://www.castironweldingrepairs.co.uk ... epairs.php
All the best,
All the best,
hello
i have done this myself several times
i just use stainless steel welding pins. Weld 2cm and tap it with a very small hammer until it is cold enough to touch it with a finger, and then continue 2 more cm until the job is done. Prepare it by grinding a groove along the crack. It's not magic, just time consuming labour. You can also buy spesial welding pins ment for cast iron. Expencive but worth it.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
no it does not need to be heated
The whole cloue is that you dont weld more than 2 cm with minimum heat(amps on the welder) and keep tapping it until cold (almost lika a woodpeccer
) Then you will not get any tension in the steel structure.
hope this make sence
Of course use of chemical metal afterwards to seal it and refurbish the surface is possibel
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
- Site Expert Team
Dextas for the UK market run with the cooling system at atmospheric pressure, i.e. unpressurised.
I have three or four engines here which run with cracked blocks, which is a common fault with the Fordson engines. The leakage is minimal provided that the crack hasn't opened up and can be controlled by using a proprietary block sealer. Try this site
http://www.vintagetractorspares.co.uk/v ... al-up.html
In your case I would be tempted to try to seal the block first rather than go to the trouble of trying to weld it. As regards resale value,
anyone who knows anything about Dextas will check to see if the block is cracked and welding it up will lower its value.
Gerald
Gerald
- Site Expert Team
Drilling a hole at the end of a crack is recommended in order to prevent the crack propagating. In this instance I would assume that the crack occured a long time ago and probably will not get any worse, if it does it will run into the bores for the core plugs.
So in view of the hassle involved to gain access to the crack I would tend to leave it as is, but keep an eye on it in case it is propagating.
Gerald
Gerald
