Starter motor
Posted: Sat Jun 05, 2010 1:30 pm
by dexta61
I have noticed that the starter motor has got a clamp over it with sort od shims underneath. This clamp is at the end of the where the power wire is connected.
Under these (thick) shims there ar openings to the start motor. Now I have not opened it, but what is the purpose of all this? Is it weather protection or holding these shims in place?
Posted: Sat Jun 05, 2010 5:12 pm
by john.n
its just a cover. the shims you describe are cork. the cover comes off so you can get to the brushes. have you got a starter motor problem?
Posted: Sat Jun 05, 2010 7:33 pm
by dexta61
She still starts, but not as good as before. I get the feeling that rpm is lower now.
Posted: Sun Jun 06, 2010 9:49 am
by Tubal Cain
Check that your battery is fully charged, and then observe how quickly the starter motor turns over. If it is still sluggish you may have a lazy starter motor, thic can occur after long use as the commutator and brushes wear and the insulation starts to break down.
Gerald
Posted: Sun Jun 06, 2010 10:23 am
by john.n
might even be the connections to the starter. crank the engine with the stop pulled out for 5-10seconds then feel along the large cables to the starter. if they are hot at one point that is where the resistance is. if you find you are replacing the starter, you can buy a starter for a major and swap the front half of the starter over (the ali casting) and you have a working starter. both starters turn the same way so no worries about changing anything there.
hope this helps.
Posted: Sun Jun 06, 2010 1:49 pm
by dexta61
Thanks for the helpful information.
I have charged the battery over night and as per the charger it was full.
When starting the relay gets hot and the start motor itself (even smoke is comming from it). The cable to the start motor is cold except for the connection to the start motor, but it is lose as well,or I can move/rotate it in the connection. The is a bolt on top.
The calbe from the tractor to the minus of the battery is hot.
Dexta 61
Posted: Sun Jun 06, 2010 7:05 pm
by john.n
try removing the large cables and clean the ends up to bare metal. reconnect them and make sure the nuts are tight. be careful with the thread on the starter motor stud. its brass i think.
hope this solves the problem.
Posted: Mon Jun 07, 2010 6:43 am
by Tubal Cain
If there is smoke coming from the starter motor, I would be inclined to remove it and strip it down or take it to an auto electrician. Is the terminal on the motor loose because the nuts are not tight, or has someone overtightened it to an extent that the stud has turned?
Gerald
