Hood Pinted!
Posted: Mon Jun 07, 2010 2:56 am
I've been working on four tractors at once over the past several months: a Ford 8N, 9n, Funk, and my Dexta. It helps to have a lot in the pipeline, I guess. Here is a shot of my '59 Dexta's front end - about 15 months ago:
This is what it looks like, now:
In a week or so, I plan on disassembling my dry-fitted engine and reassembling for the final time, with all new gaskets and seals.
Here is the dry-fitted motor:
My question is, should I be using gasket sealant when I put the gaskets in place? It seems to me that all of the gaskets were really cemented in when I tore the engine down. Are diesel motors in need of adhesion when they are reassembled? I'm much more familiar with gasoline motors, so I want to make sure I get the Dexta's diesel engine put together correctly.
You are all welcome to follow my tractor (and other) restoration ventures: http://picasaweb.google.com/tractorNstuff
Don
Don
