hi all recently told that my 58 block has been changed to a 152 what sort of problems can i expect here.
Took motor into the shop a few weeks ago as not enough compression to start and generally really stuffed.
Was under the impression that it was originally fitted with the F3-144 so ordered kit etc
The shop then tells me the liners are all wrong and to small, after measuring appears that the block is of 152 caliber.
Couple of questions
Head is indirect injection is this correct for f3-152 ?
Crank is that the same?
and what else will be different?in other words is the only difference between 152 and 144 pistons and linners?
Obviously was running well for some time but would like to do properly.
block changed from 144 to 152 Problems?
Dexta 1958?
957E 7905
C25B
957E 7905
C25B
So why would the block need to be bored, unless it was to fit a Lip liner?
My engineering shop just pressed out the 3.5 Dexta liners and pressed in new 3.6 liners, Mine is an original 1960 Dexta and had never been worked on . So deciding to do an engine rebuild we just went for a Super Dexta engine kit.
Wonder if that makes me half way between Dexta and Super Dexta?
Yorkshire man, I did this to mine and everything is still the same. What are we going to call our tractors now with this set up? An almost Super or a Super duper Dexta. We'll have to ask Ben and see what he says he's always good on these type of things. What say you Ben!YorkshireDextaMan wrote:
See ya
Mark
Mark
I think most of the machine shops are doing this as they as the can use the perkins 152 liners for m/f and the dexta . that is why they have the lipped linner now, this can open the name up to another different level.are our blue darlings now all bitas or [a s p ]if the engine has been done up like this. mine had the same done, over to BRIAN .
Gerry
Gerry
