Stop Cable
Donegal Dexta
Stop Cable
Post by Donegal Dexta »
Where does the stop cable cut the diseal supply to the engine. Does anyone have any photos of where the stop cable cuts the fuel supply in their dexta?? Cheers
Donegal Dexta
The stop cable does not stop the fuel supply as such. It moves the control rack in the pump so the pump no longer supplies fuel to the injectors.
Donegal Dexta
Stop Cable
Does anyone have a photo of how the stop cable is connected to the control rack on the pump??
Donegal Dexta
terry274
Post by terry274 »
Image[/img]
1964 Fordson Super Dexta
pjjms
Post by pjjms »
I don't have a close up picture of mine but the lever is around behind the pump between the engine block and the pump. I think the picture above is of a later model tractor with a mechanical govenor. Mine has a pneumatic govenor.
If yours is an early tractor put your hand behind the pump you will find the lever and there will also be a bracket for the cable towards the rear. To be honest the cable is in a dog of a place to connect.
Donegal Dexta
Stop Cable
Cheers quys, if anyone has a close up of the stop cable connection at the back of the pump it would be aqppreciated. Thanks.
Donegal Dexta
john.n
Post by john.n »
you can see the stop control clearly in one of the photos
http://cgi.ebay.co.uk/FORDSON-DEXTA-FUE ... uipment_RL
simco
Re: Stop Cable
Post by simco »
I have a Fordson Power Major tractor and need to replace stop cable. Available parts seem to come in 2.2 & 1.5 metres. I only require 1 metre length. Is it as simple as just cutting and reducing the lead to length required?
john.n
Re: Stop Cable
Post by john.n »
yes
