Fuel Filter Bowl - AC type
Posted: Mon Nov 08, 2010 1:07 am
by Bensdexta
This is the fuel filter bowl off my 61 Dexta.
It is marked AC on the top.
Am I missing any gaskets, seals, washers, etc?
I'm aware there should be large and smaller seals in the indentations under the top.
But is there just the spring & washer underneath the filter element?
Thanks.
Posted: Mon Nov 08, 2010 7:38 am
by Lesfen
Hi Ben,
My parts book shows more 3 items between the washer and bottom of filter:
#17> E512-CL-9 (Gasket, fuel oil filter)
#18> 116276-ES (Washer, gasket support)
#22> E1ADDN-99116-B (Seal, fuel oil filter)
Cheers,
Les
Posted: Mon Nov 08, 2010 12:53 pm
by Bensdexta
Lesfen wrote:My parts book shows more 3 items between the washer and bottom of filter:
Thanks, yes I saw that on p 104. It's all a bit confusing.
Are these consumables? Perhaps 18 isn't?
Where do I get 17, 18 & 22 from?
There's a footnote saying 18 & 22 are 'No longer serviced'. What does that mean, not needed or procure locally??
Presumeably these parts are to seal the hole in the bottom of the filter and make the fuel flow out of the side of the filter?
Thanks,
Posted: Mon Nov 08, 2010 3:05 pm
by Lesfen
Ben,
I have found, over here, 'no longer serviced' means the depot no longer bothers to carry them but a dealer might still have some old stock.
I think #18 will be the tough one to find as it appears to be a holder for sealing rings 17 & 22. (square shouldered orings might be available locally)
A wrecker might have a complete unit.
Or make one. (I was impressed by Stephen's and your fuel primers!)
I'll have a look at ours tonight and measure it up if that helps.
Les
Posted: Mon Nov 08, 2010 3:16 pm
by Bensdexta
Lesfen wrote:I have found, over here, 'no longer serviced' means the depot no longer bothers to carry them but a dealer might still have some old stock.
Or make one.
Les,
Any clues on what should be there would be much appreciated!
Posted: Tue Nov 09, 2010 7:10 am
by Lesfen
Ben,
Took a look at the AC fuel filter on a '62 Super Dexta that is not running and to my surprise found exactly what you did>>> just a washer and a spring!?
(Has AC, D08-1 and FF23 Element cast on the top of the head.)
Tomorrow I'll check out our original '62 Super Dexta.
Later,
Les
AC Fuel Filter - top
Posted: Tue Nov 09, 2010 12:16 pm
by Bensdexta
Lesfen wrote:Took a look at the AC fuel filter on a '62 Super Dexta that is not running and to my surprise found exactly what you did>>> just a washer and a spring!?
Les,
Ah ha!!
It can't be right though, as a seal is needed to block the hole in the bottom of the filter, and make the fuel flow from the outside of the filter into the inner core, thence up and out through the outlet near the centre of the filter assy top.
Here are pics of my top, sounds like the same as your Super D.
Note that the casting marked "IN" is blank. The inlet is the unmarked casting opposite.
Here is the underside with the outlet by the bleed screw upper centre.
Look forward to hearing what you discover on your other Super D!!
Many thanks,
Re: AC Fuel Filter - top
Posted: Wed Nov 10, 2010 12:01 am
by YorkshireDextaMan
Bensdexta wrote:Lesfen wrote:Took a look at the AC fuel filter on a '62 Super Dexta that is not running and to my surprise found exactly what you did>>> just a washer and a spring!?
Les,
Ah ha!!
Perhaps a new filter would have a seal attatched. i got a filter from Agriline and it had a cork seal at each end
Note that the casting marked "IN" is blank. The inlet is the unmaked casting opposite.
Many thanks,
Posted: Wed Nov 10, 2010 8:01 am
by Lesfen
Hey Ben,
Your 'Ah ha!' could be right on!
Found the very same setup on our original '62 Super Dexta
(Just a spring and a washer.... although this washer is somewhat thinner and has a bit larger diameter. (0.026" thick, 0.520" ID and 1/341" OD)
It seems that a regular flat washer has been substituted on the 1st tractor I looked at.
Same casting on the filter head with a EIADDN-99162B filter inside.
Unfortunately the spring is in two pieces! (Glad we had to take a look!)
It looks to be the same as the first one which has 5.5 coils, wire diameter of .065", outside diameter is 0.728" and is 1.212" long.
(Looks just like your photo.)
Also have a EIADDN-99162A filter on the shelf which is listed for the US market in the parts book.
It is slightly taller and has larger ID thin, flat gaskets glued on the top and bottom and comes with the #22 seal.
Our and your washers look to have a larger diameter that what is shown in the parts book but maybe it is only a drawing?
Now I'm really wondering if that is the way they came as we got this S Dexta in '63 with under 100 hours on it and have serviced it ourselves!
Les
Posted: Wed Nov 10, 2010 1:32 pm
by Bensdexta
Lesfen wrote:Found the very same setup on our original '62 Super Dexta
My spring and washer have near enough same dims as yours. As you say the washer is pretty thin.
So it looks like these are orignal parts - our Dx seems to be fairly original although she was 12yr when we got her.
I think I will replace my spring as it's badly corroded in one place, and we have a 'spring' warehouse just down the road.
So the answer seems to be just sit the filter on a largish O-ring that fits snugly around the central rod. Must see if my filter has a cork seal at the end as YDM says.
Many thanks for the detective work
