Wonder if anyone can help. I have a 1963 Super Dexta. Problem I have is the Diff Lock is only engaging below the foot rest! Seems to be working fine once engaged. The operating lever seems to be too low down. When the adjusting screw is opened to allow it to come up, there is a lot of freeplay. The spring link is adjusted as short as possible. Have run out of anything else to adjust! Is it possible to move the operating lever up without having to take everything apart.
Thanks for any information.
Jeff
