Solenoid clicking
Posted: Mon Jun 27, 2011 4:44 pm
by niallsdexta
Please do not shot me as electric is not my strong point! :roll: My Super has developed a problem of not starting, the solenoid just keeps opening and closing but the tractor does not turn over, I have tried the earth on the battery and this is good, and also onto the body of the tractor, good clean connection, so no problem there, there is also a good charge in the battery, I replaced the solenoid for the not so pretty but supposedly better square type, no help, so I am at my wits end here, could it be the tarter motor? :scratchhead:
Any help anyone can give I will really appreciate.
Niall
Re: Solenoid clicking
Posted: Mon Jun 27, 2011 7:19 pm
by roromac
If you've replaced the solenoid and it still ticks that is odd as it should, with a good earth, good charge and good live just clunk once. If you short the two terminals on the solenoid - in other words bybass it, then the starter motor should spin. If it does not then your problem is either the connection battery to solenoid or more likely after the solenoid - possibly the motor. Take care to only short those two - do not touch the body. - a ring spanner pressed against the two should work. As long as the starter lever isn't pushed, there's no danger of moving anything other than the starter motor.
Rob
Posted: Mon Jun 27, 2011 7:25 pm
by roromac
Thinking about it, the problem has to be the wiring to the solenoid as only a poor voltage would allow the solenoid to tick. And you've replaced the unit so it's unlikely that two would be faulty. Worth the try of shorting the two major terminals though just to prove the point.
Rob
Posted: Mon Jun 27, 2011 8:14 pm
by Bensdexta
Are you sure the battery is good? Clicking solonoid is classic symptom of duff battery. How old is the battery? What voltage is it holding when you try to start (ie with battery under load)? Does it start OK with another battery or jumped off a largish car?
Posted: Tue Jun 28, 2011 12:50 am
by Lesfen
Niall,
We've often had to scrape or brush the battery posts and clamp on ours.
For some reason it builds up a glaze between the two on the Dexta?
Much more than any other tractor or vehicle we have.
Les
Posted: Tue Jun 28, 2011 7:28 am
Just a small point! Shorting across the terminals on the solenoid could arc and burn the posts so that you cannot get the nuts off. Been there, done that, eaten the pie! :cry:
Clicking solenoid is usually bad connection as has been covered in other posts.
Posted: Wed Jul 06, 2011 4:50 pm
by niallsdexta
Hi Guys,
Just to give you all an update on how things went, after pulling my hair out looking at all sorts and then deciding that I must need a new battery, I noticed (somehow) that when the solenoid was clicking the side lights of the tractor or the horn was not working at all, so I thought thats odd, checked my battery kill switch and it was turned right around, I rotated it back a wee bit and the lights came on full! :shock: tryed again and she started up like her first day, my problem was the auld kill switch all along, removed it from circuit and shes been a good girl ever since!
I am oure chuffed! :beer:
Thanks for your help with this one, it just goes to show be persistant as you never know where the problem is!
Posted: Wed Jul 06, 2011 7:17 pm
by YorkshireDextaMan
A clear case of "I saw later" Don't you just wish Dexta's could speak.
