Front axle pin
Posted: Mon Sep 12, 2011 11:32 am
by russelm
Ok, so my front axle pin is VERY worn (will post pics this evening) and I have ordered a new pin and bush which have arrived today.
The question is, should the pin be a comfortable fit within the bush as there is quite a bit of slop (note the bush is not fitted yet). The parts are Sparex items.
As an addition, my pin setup had two washers and a spacer on it and looks to have never been taken apart before (I note from searching the old posts that there have been questions regarding this)
Re: Front axle pin
Posted: Mon Sep 12, 2011 1:09 pm
by russelm
Here's a quick picture of the issue:
Re: Front axle pin
Posted: Mon Sep 12, 2011 8:13 pm
by russelm
Ok, so measured the bush internal diameter and its 45mm.
The pin is 44.5mm
This is resulting in a fair bit of potential play which I am guessing should not be there?
Re: Front axle pin
Posted: Mon Sep 12, 2011 8:50 pm
by Bensdexta
Hi Mark,
Seems more than my new pin & bush. Can't measure it right now, but I remember it being a fairly snug fit.
Re: Front axle pin
Posted: Mon Sep 12, 2011 9:03 pm
by russelm
Thanks Ben
I would expect it to be a snug fit given the type of bush used so I will have to get onto the supplier tomorrow
My old one however wasn't a snug fit any more!
Re: Front axle pin
Posted: Mon Sep 12, 2011 10:47 pm
by Bensdexta
russelm wrote:Ok, so measured the bush internal diameter and its 45mm. The pin is 44.5mm
I believe pin dia should be 44.5mm. This is the ID of the spacer that Dextrous made me which fits my pin very snugly, so I guess that your bush ID is a shade too big. I guess one could turn up a bespoke bush on a lathe
Re: Front axle pin
Posted: Tue Sep 13, 2011 11:02 am
by Bensdexta
Mark,
Just measured my new pin for you with a feeler gauge and the gap between pin and bush is about 0.18mm.
Re: Front axle pin
Posted: Tue Sep 13, 2011 1:46 pm
by russelm
So, there appears to be conflicting info on the web with reference to the front axle pin bush size, so far I have:
EMMARK: 48.7mm (OD) x 44.8mm (ID) x 37.9mm (L)
SIlver Fox: 49mm (OD) x 45mm (ID) x 38mm (L)
The latter could just be a rounded figure
Re: Front axle pin
Posted: Tue Sep 13, 2011 1:56 pm
by Bensdexta
russelm wrote:So, there appears to be conflicting info on the web with reference to the front axle pin bush size, so far I have:
But pin and bush should be a matched pair surely?
Re: Front axle pin
Posted: Thu Sep 15, 2011 8:26 pm
by marcusgs
Should be a very snug fit Mark. Vapormatic ones for Dexta are good.
Re: Front axle pin
Posted: Thu Sep 15, 2011 8:58 pm
by Bensdexta
marcusgs wrote:Should be a very snug fit Mark. Vapormatic ones for Dexta are good.
Can you hazard a figure for the snugness
Re: Front axle pin
Posted: Fri Sep 16, 2011 8:14 am
by russelm
Thanks.
Certainly nothing snug about this one (sadly) and I am still awaiting feedback from the seller
Re: Front axle pin
Posted: Sat Sep 17, 2011 8:26 am
by pjjms
You may not have a problem. I suspect the bush is a split DU bush. I have never seen a DU bush that did not close up the ID a little when installed. It will be interesting to see what the ID measures after you press it in. If you don't have a press use a bolt with large washers to draw it into place. Don't use a hammer or punch on DU bushes.
All that assumes you don't have a solid bush.
Re: Front axle pin
Posted: Sat Sep 17, 2011 8:25 pm
by russelm
It is a solid bush
Re: Front axle pin
Posted: Sat Sep 17, 2011 9:42 pm
by marcusgs
Pin diamater + 0.1mm
Re: Front axle pin
Posted: Thu Jan 26, 2012 9:25 am
by russelm
Well, I had no joy from the seller or the original supplier (Sparex).
So I bought another new pin and bush from a well known supplier and guess what, there the same!.
And with the bush fitted its no 'snugger' either!
Dam annoying this as the front section is all finished bar the body work and this pin issue!
Re: Front axle pin
Posted: Thu Jan 26, 2012 9:31 am
by tom lad
hi mate
how much play / tolerance is there now ? with new pin and bush .
Re: Front axle pin
Posted: Thu Jan 26, 2012 3:11 pm
by YorkshireDextaMan
Part number 957E-3127 From a CNH Dealer. allmost certain to be available , and it will be genuine. Jim
Re: Front axle pin
Posted: Fri Jan 27, 2012 9:03 am
by russelm
Play is the same as before which makes me think that the parts may be from the same manufacturer.
I have contacted the seller so will update on progress.
