1959 Seat pan, logo and number plate bracket
Three questions all relating to my grandfathers 1959 Dexta. I am not restoring it, just keeping it running, but trying to get it back to as close to original fit, for the time when I do eventually restore it properly
Would it have had a Fordson badge or similar down the side of the bonnet? cant see any holes where one might have been fitted? just want to know if I should put one back on or not as I thinI do have one from spares kept from tractors I have broken last year.
Same question regarding the number plate bracket on the rear axle. The number plate light is there, and the number has always been painted on the rear housing. In my pile of bits I found a bracket that fits opposite the number plate light, that would support the other end of the number plate. Would it have been there originally, or was this a later addition?
And finally the seat pan.
Can anyone tell me if this is the original early seat pan design, or if my father or grandfather changed it some time since they bought it.
I was going to junk the worse pan and put on a better one, so repaired the better one, went to fit it and noticed that the one on the tractor was different.
I have now repaired the one that was on the tractor as well, so have both, but would like to put the correct one back on.
Oh, off topic....was there a clear out of the old forum user database? Just that I have had to re-register this morning. I have ben away for a while, and have not checked the forum for a while now, so probably missed any system /admin messages?
Neil
Note ridges down side, no remains of X shaped moldings /ribs, and note the mod under the seat, that helps support the old broken seat, and also is a useful second tool box for toplink pins etc.
Next to the better one of different design with moldings
Neil
npaisnel,
Comparing my Dexta which is a 1960 to your 1959 the seat pan should have grooves to get rid of any rainwater from the sitting surface, like the one on the R/H side of your photo.
Regarding the badge, a 1959 Dexta would only have the vertical "Fordson Dexta" badge on the centre section of the front cowling between the two grilles, If someone can correct me if I'm wrong but I dont think there was any badge on the bonnet.
The number plate brackets as I'm led to believe were an extra and not supplied with a new tractor as some tractors were never registered and therefore did not require these brackets.
Regards,
Barry
Regards,
Barry
Ok, thanks.
The old seat did have D shaped drain holes, which I have now cut in. If it is not Dexta, wonder where it came from? anyone any idea
Strange that it had 1 number plate bracket, with the number plate light, and not the other. We have had it since new, and no one recalls doing any work to the rear axle that might have meant taking the other bracket off, and as far as they are aware the reg number was always painted on from new
Neil
Neil
Npaisnel,
I agree with Barry T, I own a 1959 Dexta and it had the groves to let the rain through, and a back rest. I broke my back in 1990, and I had to buy a hydraulic seat for mine, couldn't stand the jarring of the original seat. I still have the old one put up in the shed, just in case I need it.
Also my Dexta had badges on the bonnet running length ways, that said Fordson Dexta on them. That's the only badges I've seen on the bonnet. I'm sure someone else will get in this thread to help you some more.
Mark
PS
After some thought I do remember seeing a picture of a Dexta with a Decal on the bonnet, I don't remember what year it was though.
Mark
PS
See ya
Mark
Mark
I can understand about groves to let the rain drain, but to let the rain out, the grooves would have to have a hole at the bottom of it...no holes in the grooves of my grooved seat. The D shaped holes are on the flat area, would have been used to strap the seat cushion down. I reckon the moulded groves are more for strength rather than drain water.
I think the flat based one would have had a back rest also, the holes are there, and do line up with the back rest of the later seat.
I should be able to meet up with a chap down the road from me that used to be a mechanic on them when they were new at the local dealership here in Jersey. Have to make a point of seeing him this weekend. He still restores old Dextas himself. Maybe he can clear this up.
Thanks All
Neil
Thanks All
Neil
further to the comment i made in relation to Stefans seat i am sure i have read somewhere ( just remembered it is listed as an accesserie in a booklet called fordson dexta facts i downloaded from somewhere - this site in fact!! see main page/ dexta) that there were 2 seats standard and "delux". the delux had the backrest i believe. The brochure refers to it as "Extra comfort seat"
Mike
Hi Neil
Sorry about the little error. If you search back to 19 April 2008 you will see a post by KennyH, My Dexta, showing his smart restored Dexta which has a seat pan with the bulge. I'm not sure what year Kenny's Dexta is but I'm sure it must be close to yours. Just curious but why would that bulge have been put there in the first place?
Kind regards
Mervyn
Kind regards
Mervyn
