Maximum Lift Load
Posted: Wed Oct 26, 2011 8:46 pm
by jeveriss
Could anyone tell me what the maximum weight the 3 point hitch will take on a Dexta, I'm looking at buying a box or bucket for moving soil/gravel/hardcore around.
Re: Maximum Lift Load
Posted: Wed Oct 26, 2011 10:42 pm
by YorkshireDextaMan
You can usually tell when maximum weight of the Hydraulics has been reached when the front wheels lift off the ground,
Posted: Thu Oct 27, 2011 8:05 am
by jeveriss
I could always fit some casters to the bottom of the box.
Posted: Thu Oct 27, 2011 3:54 pm
by Bensdexta
jeveriss wrote:Hi,
Could anyone tell me what the maximum weight the 3 point hitch will take on a Dexta, I'm looking at buying a box or bucket for moving soil/gravel/hardcore around.Cheers
I think it should lift 1/2 ton on the 3PL without complaining. A 5ft wide box is enough for a Dexta.
Posted: Thu Oct 27, 2011 11:42 pm
by dexta roadless
The information I found is 1850 lbs(840 kgs). I think that is measured 60 cm behind the liftarms.
Posted: Fri Oct 28, 2011 12:00 am
by Bensdexta
dexta roadless wrote:The information I found is 1850 lbs(840 kgs). I think that is measured 60 cm behind the liftarms.
That's interesting. Where did you find that?
Yes a good point about the distance of the load behind the rear axle. The arms will lift a greater load the nearer the load is to the rear axle.
Posted: Fri Oct 28, 2011 12:53 am
by dexta roadless
I just took a search on the google and found it here.
http://vintagetractorengineer.com/2009/ ... xter-data/
