Auxillary valve leak
Ive just started my dexta which has not been run for 2 years. Whilst running ive noticed oil leaking from the auxillary control valve. Its coming from the hole immediatly behind the control valve. Its a hole with what looks like a roll pin in it. Ive looked it up in the parts manual, its on fig 10 of the manual and is numbered item 10 and 11, namely a Retainer Oil Passage and Seal Oil Passage. Can anyone tell me why this has started leaking,( it wasnt before being stored) and the remedy etc/ Many Thanks... Oh and by the way it fired up first time without heat after 2 years.
1961 Dexta, 1957 FE35 and 1966 Eicher ES101 (of which im always looking for spares).
Re: Auxillary valve leak
I have the same problem, hope you get the answer
Drive out pin, remove plug and fit new "O" rings. You may need to drill and tap the plug to get a small screw into it to give you purchase to lever with a screw driver.
We always kept a number of small ball bearings that we used to feed down the galleries and lever against to pop the plugs out, when we were servicing them.
"O" rings perish after many years and give these problems.
Thanks Brian for your advice. Would it be best to remove the unit or to do it in situ? Do you know if the plugs are available still and who does them? Many Thanks for your help.
Best to take it off and on the bench.
You should not need any plugs, they do not wear out. You only drill into the plug far enough to get a few threads for the screw/bolt to get a grip, it does not take a lot of force to remove them. The plug is about 15mm deep so you will not need to drill through it.
I also have exactly the same problem as well as a leak from the hydraulic pump flange (seperate post in July 2012). Thishydraulic pump flange has been nearly sorted; renewed thanks to those that replied.
Back to this post;
I am slighty confused as the down loaded manual I have the parts are shown on page 3 figure FO563; I have a 1958 Dexta. The part numbers are 48 (selector valve spool) 49 Detent assembly; are we talking about the samer parts ?
My main question is what size are the o rings that need replacing; I have a box with many various imperial sizes; will that do or is there a special Fordson/Dexta size ?
Back to this post;
just like to chip in here as i had the sme problem tried useing the correct hyd o rings which
kept leaking eventualy i tried as a last resort a 15mm o ring from a plumbing fitting which
is slightly thicker than the hyd ring up untill now a year and a half is stil holding good ,
ring came out of a grey plastic pipe fitting , although made for water is holding good
sky blue
sky blue
