Tyres
Posted: Tue Apr 03, 2012 12:41 pm
by niallsdexta
Hi All,
This has probably been asked already on here but I have a 62 Super Dexta, can anyone tell me the correct tyres to fit on this model, also it is mainly for play and to go on tractor runs, I do not possess a plough and I have no intention on ploughing so do I need radial or Cross ply?
Also for road runs and the likes what sort of PSI should I have in there?
Thanks for the help.
Niall
Re: Tyres
Posted: Tue Apr 03, 2012 3:30 pm
by 60dexta
My 1960 standard dexta has 10x24 I think.
I noticed in the 'Dexta oil' thread there is an oil spec sheet..... but it also shows the tyre pressures as 12 PSI rear and 34 for the front.
Edit: Link .. http://www.fordsontractorpages.nl/manua ... lspecs.pdf
Rob
Re: Tyres
Posted: Tue Apr 03, 2012 6:56 pm
by john.n
dexta rims are 28 inch,
tyres listed in the manual are:
11x28
10x28
13x28
12x28 (export only)
Regards,
Re: Tyres
Posted: Tue Apr 03, 2012 7:54 pm
by 60dexta
john.n wrote:dexta rims are 28 inch,
11x28
10x28
13x28
12x28 (export only)
Regards,
Err... yes. Mine must be 10x28. 24" rims would be small.
Rob
Re: Tyres
Posted: Tue Apr 03, 2012 10:01 pm
by GERRY
12-4-28 ithink would do you , book says 12 psi but around between 15 an 18
when on road ithink ,12 would be for feild work , 20 to 24 front possible , if tractor is to bouncy on road then
reduce this to suit. :lol: Gerry
Re: Tyres
Posted: Tue Apr 03, 2012 11:57 pm
by Bensdexta
See http://www.fordsontractorpages.nl/phpbb ... ilit=tyres
A search on tyres etc will bring up quite a few more. :wink:
