Can anyone tell me if the large axle nut that holds the bearing on a Super Dexta is the same nut as the 1965 Ford 2000? The Ford part number is C5NN4N001A and it is called a bearing lock nut.
Thanks, Terry
axle nut
If anyone else needs the answer to this post, it is yes the part number C5NN4N001A is correct for the bearing lock nut. The New Holland dealer wanted $90 US dollars for this nut. Got one from Yesterdays Tractor for $12 plus shipping. The new one from YT did not have the nylon locking ring on top, however.
Terry
Terry
1964 Fordson Super Dexta
