Tach drive gear replacement?
Posted: Mon Nov 19, 2012 3:07 pm
Hello
My neighbors dexta has a new tach and a good cable,but the drive from the rear of the IP is worn out and will not turn the cable.
I have removed the 4 bolts from the rear of the IP but the gear housing is frozen in place-is there anything more required to remove that gear/housing?
On a side note,the fuel tap/plunger under the tank has ben replaced with new and now the engine floods with fuel through the line going to the intake heater.
Is there a check valve in the tap apparatus that can be serviced or should I add a tap to that line-replacing the tank valve again is not an option at this point.
