Dexta Live Clutch
marcusgs
Dexta Live Clutch
Post by marcusgs »
Does anyone know if a Dexta Live clutch assembly can be fitted onto a single clutch flywheel?
Thanks,
Mark
WayneB
Re: Dexta Live Clutch
Post by WayneB »
Flywheel is the same. Yes. However the transmission is different. To attain Live PTO, you will need dual clutch assy and live transmission.
Wayne
marcusgs
Post by marcusgs »
Hi Wayne, I have managed to get a live gearbox, I just need to source a dual clutch assembly now.
Is everything rearward of the gearbox the same? I.E. trumpets, back end.
Thanks,
Mark
pbufton
Post by pbufton »
Do both have diff lock?
marcusgs
Post by marcusgs »
No, one does, one does not...
Regards,
Mark
