PTO conversion
PTO conversion
i have the petrol dexta with a single stage clutch. can i upgrade to double clutch (live pto)? what would i need to purchase ?
Re: PTO conversion
into the dexta specs it sais the live pto double clutch was optional
Re: PTO conversion
http://www.fordsontractorpages.nl/phpbb ... 930&p=6210
Possible but quite a bit of work.
A single clutch is stronger and simpler than a double so swapping may not be worth it, depending on what you want to do.
Re: PTO conversion
wanted to blow snow but i think im just as well off to buy another tractor
Re: PTO conversion
To convert involves quite a lot of expense unless you have a donor tractor. You need to replace the gearbox, clutch and possibly rear axle depending on the age of your donor and receiver tractors. In all honesty, yes it is possible but another tractor might be the best way.
You cannot have too many Fordsons.
