Gap between bottom hose and fan belt
Posted: Sun Nov 16, 2008 2:09 am
by aldo
Hi everyone.
I just installed a new bottom hose and with a slight twist of the hose when tightening the clamp, the biggest gap I can get is about 4-5 mm. That's seems a bit close for comfort.
Just wondering what gap you all have between the bottom hose and fan belt, at the nearest point.
Posted: Sun Nov 16, 2008 9:55 am
by Oscar
Ah, yes, I remember that from my Dexta as well. The gap is quite small. When I replaced the hose, the old one was partly worn where the fan belt had bitten into it.
This is how I solved it. I took an old tin can and sawed out a section of the curved vertical part. This I attached on the hose between the fan belt and the hose. I believe I made 4 notches in the piece of tin and secured it with 2 tie-wraps that went around the hose and were kept in place by the notches. Worked fine for me for many years without any problems.
Barry Thomas (BarryT on the forum) owns my Dexta now. Perhaps he is willing to post a picture.
Cheers!
Oscar
Posted: Sun Nov 16, 2008 10:09 pm
by terry274
Aldo, I just went out and checked the clearance on my belt/hose. It is very close, less than 4 MM. The belt does not appear to have ever rubbed the hose however.
Terry
Posted: Mon Nov 17, 2008 10:20 am
by aldo
Thanks Oscar, and good idea about the tin, I will do that just in case.
Terry, good to hear that your gap is also very small.
I wasn't sure what size gap is normal, because the old hose I took off was a home made job (not made for the Dexta), and also the front end is modified to take the front end loader. The new hose fitted perfectly, so now I know everything is okay.
Posted: Mon Nov 17, 2008 2:07 pm
by BarryT
aldo,
I would not worry about the small gap approx 5mm all Dextas that I have seen are the same, when you fit the new hose twist it as much as possible to get the maximum clearance and then tighten up, get someone else to twist it for you while you do the tightening up, should do the trick. Oscar I have replaced the hoses on Ol Blue and therefore cannot take a photo, but I clearly remember your handy work with the tin sheet!!
Regards,
Barry
