I wanting to add a hydraulic outlet to my super dexta so I can use a haybine that has a single acting hydraulic cylinder. This is what Im working with. Im just not sure what needs to be done to make this work. Can someone point me in the right direction? Thanks
It's quite easy. Take out theplug you have marked "1" and screw in a 1/2" pipe connection of some sort. when you use it, pull out the knob you have marked 2 activate the external service and use it by operating the main handle.
6o Dexta Roadless
62 Dexta
63 Super Dexta
75 Shilter UT
62 Aebi
another question, because the picture shows it very good: How is the valve (Nr. 2 in the photo above) dismantled, which switches between 3pt linkage and the external pipe? It looks similar to that on my super major, but mine does not move.
Can I turn the big round cover?
To my surprise the the aux knob works good. I expected it to be froze being that the knob is missing. I just put a washer and nut on the threads to make it easier to pull. Can anyone tell me how to check the hydraulic fluid level?
